According to the Rane notes, the cable's shield is "an extension of the chassis". http://www.rane.com/note151.html
nielsk said:So this works for you with phantom powered mics?
Jensen shows the pin 1 shield connected to chassis on their mic preamp schematics.john12ax7 said:I was wondering about that. How is pin1 normally connected on mic pre inputs?
couldn't disagree more.nielsk said:Remember, those Rane notes must be taken with a grain of salt... more of a "tips for beginners" guide than a bible.
No, it doesn't seem like a good idea - but the standard for phantom power is "grandfathered in" more than an elegantly thought out methodology.So this works for you with phantom powered mics? Using the equipment shield path for the return for phantom does NOT seem like a good idea.
+1[silent:arts] said:the "pin 1" discussions will never find a perfect solution for all.
this is why the GDIY511 Rack has options for pin 1 8)
chunger said:Not an expert by any stretch of the imagination, but the 2 racks here have pin 1 connected to chassis as suggested "standard". Everything works in critical use all across the rack (phantom power, no noise problems, etc.). If problems come up, I have options and can re-investigate.
Correct 'Chunger. From the rack side, they are fully separate ground return paths to the star ground point.chunger said:As I understand it, the chassis and ground are supposed to connect at the star ground and only at the star ground in the PSU. This is how I wired it.
jsteiger said:Correct 'Chunger. From the rack side, they are fully separate ground return paths to the star ground point.chunger said:As I understand it, the chassis and ground are supposed to connect at the star ground and only at the star ground in the PSU. This is how I wired it.
sahib said:Good stuff Chunger. Great build.
Third run is in production and planned to be available within four to five weeks.
