Well shoot, the last thing I want to do is interrupt a good, wholesome internet squabble about who's vintage clone is better than who's vintage original mic. . . thought I'd interject a quick little mod to the specific capsule mount that's provided with this body. The design is growing on me a bit because it's really easily and cleanly adjustable for height. Originally, I was a bit bummed that the capsule sits pretty low in the headbasket, but because it is low, you can use a standoff of whatever height you decide to finely tune the capsule height and experiment with it non-destructively.
Here, I will be using a 6mm height M3 threaded standoff to raise the position of the capsule.
First step is to remove the headbasket to reveal the capsule.
Next, carefully remove the capsule and saddle. It's strongly advised to not do this with a camera in one hand because the capsule is delicate
With the saddle removed, we can easily install our standoff to raise the post height by 6mm.
And, reinstall the saddle and capsule.
Humans win!
I think the capsule height can go up another 2mm so an 8mm standoff can be used here to get the capsule position proportionally a bit closer to the original U87 position, but other variables may play a bigger role in sonic effects at this point like the headbasket being generally bigger than the original as well as the different meshing specs. I like this simple mod a lot. It looks like the capsule is where it should be.
