Animatic
I'd flip the cap PS board 180 and move the power supply and switches over to the other side,
and then also move the DI side over with the mic input. The redo the face plate.
The OT and the PT can be in th same area as long as they are rotated
and their inductance fields are 90 degrees off angle, you have enough room there.
Move OT up front and PT to the rear and make sure they have the
iron's magnetic fields radiating at different angles. The PT should also
not have a field aiming at the tubes. Look at old Fender amp pictures
or old HiFi stuff for a reference.
DC heaters, good,
but also the grid plate cath wires crossing is not good. Good eye kh.
Not near as bad as the In Tranz covered with AC.
Don't feel bad tube amps are another world, and not necessarily intuitive.
I came to Prodigy because I met PRR at Hoffman BBS, he mention this place.
It's a space specifically about building tube amps
http://www.el34world.com/Forum/index.php
Lots of useful info and examples about tube amp design.
Mostly guitar amps, but high gain preamps are real hard to get right,
so it applys to your project. Maybe go check it out and look at some
of the links to finished amps.
Good amp dress is religion there. :grin:
Note on NYD's unit, if I remember correctly, his PS isn't even in the same box.
Don't worry you will get this running well and you WILL be happy.
I have the parts for 2 of these, but I am waiting for the custom iron to be made. And hoping they can do a input tranz properly here too.
DC heaters, good,
