MasonAtom
I've been playing around with this a bit in LTSpice. It seems as though you can drive this from a 12AU7 cathode follower, with about 10k on the cathode. Higher resistances bring down the amount of boost you achieve (I started at 47k and only got about +5.5 dB for max).
Because the output impedance of the 12AU7 cathode follower is probably still a tad higher than Dave's recommended 100 ohms, it looks like you have to scale the total resistance of the bank if you want to maintain +10 dB boost (in this case, about 1.8k total series resistance does the trick). The frequency response and q looks really good. Here is an sim with 275Hz, 1.1k, and 5.5k based on Dave's inductor/cap choices for related frequencies. If I build this, I'll probably go for 4 or 5 frequencies per band.
I'm going to have to rescale the resistors to maintain even 2dB boosts per rotation, but that should be easy enough.
Mason
Mason
