the eq circuit is done. still waiting for a mains transformer for the tube amp.
i currently have the eq hooked up to a JLM pre amp, with adequate fixed gain and with a carnhill vtb9049 OT for some initial listening.
sounds a bit like heaven.
very interesting eq. i feel that its almost like a one band eq because all the bands interacts with each other.
for ex, if id like to have an impressive low end, id try cutting the 300hz or 400hz and perhaps adjust the lows to taste.
some of the highs and perhaps 1k might need a bit wider Q.
i have pushed it a bit with music, like 14-16dBu, but haven't heard any obvious hard saturation. its actually quite transparent but in the same time euphoric and take cares of the edgy stuff in the mix. perhaps its the carnhill OT that gives that deep and sweet complete image. I'm very pleased with current results of it.
i noticed that i get some low volume hum when the unit sits on my adda and have dialed in some cut/boost in mid and lows. its not loud enough as it is but if theres for ex, lots of compression or silence in the music it could be a problem. so I'm thinking about some shielding work using thick pieces of metal under and over the inductors. perhaps even relocate the inductors so they take place in the middle of the box, to get them as far away from radiation from beneath and above.
however if i remove the eq from the adda the hum goes away, so worst case scenario is to find its place in the rack.
love this eq!
