stickjam
Working on a design requiring bipolarizing the output a multiplying DAC, the application notes indicate the use of very high precision resistors, this got me thinking about component tolerance ratings and accuracy.
Taking tempco and other environmental factors aside, conventional wisdom and statistics would say that if you needed a resistor whose value was within 0.1% of 1Kohm; by testing a large batch of 1K resistors rated at 1% you might be able to find around 1 out of 10 of them falling within the 0.1% accuracy range.
However, considering that a manufacturer offers several categories of 1/4watt metal film resistors in different tolerances of 5%, 2%, 1%, 0.5%, 0.1%, what are the chances that a 1% resistor is also guaranteed to be off by at least 0.5%? (a 5% resistor will always be off by at least 2%, etc.)
Is this a reality in resistor/capacitor manufacturing? If so, are any specific brands and lines better than others in this regard? Just asking because I'm in a restocking mood. ;D
