Official C12 Clone - Build and Support Thread
rock soderstrom
Tour de France
Berlin
I purchased a Mic Parts VSP1 kit to relace the Guts of an Alctron PSU...It's not too much $$ and made a night and day difference in the sound quality. No regrets at all!!
I find 200 bugs for a PCB and a few components + Neutrik sockets a bit much. What is so special about this PSU upgrade? I would be interested in a photo of this PCB.
cfanzalone
Member
West Virginia
Ahhh, most people do not understand the importance of a god power supply...It's well worth the money. As I said in my review "Why spend beaucoup $$ and time on a fantastic mic build (Mine is an Avantone completely gutted with a 251 circuit, Cinemag 13114 Xfmr and a real AKG CK12 Brass capsule) and have the sound compromised by a "so-so (at best) stock PSU"...The sound difference is amazing. MUCH more clarity thru the entire mic range! I did A/B recordings...the proof is in the pudding.
cfanzalone
Member
West Virginia
Oh, and the Neutrik sockets...the stock PSU's sockets were so loose and rickety they needed to be replaced...'Couldn't get a secure connection...you get what you pay for...
rock soderstrom
Tour de France
Berlin
Thanks for the photo. I have never claimed that a good PSU is not important, not a word, but I find it simply too expensive. Believe me, I've built a few PSUs in my life and maybe it's because I have a hard time spending that much money on what I see. I would just design it myself including the PCB because I enjoy it.
For people who can't or don't want to do that, maybe this is a good deal. The main thing is that you are happy with your result. All good.
rock soderstrom
Tour de France
Berlin
Yeah, everyone knows that the standard sockets are not of the best quality.
I'm just making a line under the unit prices of the components I see in this quote. When I add that up, I come up with about $30 total.
cfanzalone
Member
West Virginia
Hi, Sure, all depending on one's abilities. I meant nothing derogatory towards you personally...I've just found that most people don't realize the importance. I've been inside of about every mic in the world, modded every "pro-sumer" mic preamp but not adept at building power supplies. I know my limitations. You're correct, If one is happy with the results that is the key.
Best regards!
rock soderstrom
Tour de France
Berlin
A really well-intentioned tip, connect the yellow-green protective conductor PE to the housing, even during testing. Otherwise you deactivate important protective functions and put yourself and others in danger.
lightningbefore
GDIY Supporter
@cfanzalone did you have to do any specific changes to make it compatible with your C12? I have the VPS1 as well (prebuilt) and a V-47 (I built) and am curious if any mods are required to use it in various C12 builds (I'm not confident in my PSU abilities at all).
cfanzalone
Member
West Virginia
Hi, I made a 251, not a C12...It worked perfectly upon completion (no mods), but read the earlier threads where I admit I'm not good at all with PSU's either.....I can't say, as there may be different voltages different mics like to different areas... That much I do know...Best check with Mic Parts for these kind of specifics since you got the PSU from them. Their customer service is great!...
'Sorry I can't help more...
Best regards
cariocaman85
Do you think it is better than the psu circuit shown in this thread (not the stock alctron). In what way?
cfanzalone
Member
West Virginia
Actually, it was for an Apex 460...'sorry...but essentially the same thing, Alctron, Apex, Avantone...I'm going to post a pic of the stock PSU (most stock PSU's aren't reliable in their voltages...I once had an Avantone PSU that came with the CV12 that was so far out of wack I couldn't believe it...worthless AND could have damaged the capsule with excess voltage)...
You tell me! Far better components, adjustable B+ and heater voltage, 'ramp up' power...mostly better sound!!! Night and day difference...clearer, cleaner, punchier...etc
Best regards
andYz00m
GDIY Supporter
Santa Cruz, CA, USA
Question, I know in the calibration were testing B+ out of the PSU to 120V. When im measuring plate voltage at the tube socket its more like 78V due to R17. In the 6072 data sheet it states the tube can run a lot higher plate voltage. What is the nominal plate voltage for the 6072 in this circuit?
Im assuming its around 78V but curious.
cariocaman85
Best regards
Sorry I did not mean that. I'm sure it's better than the stock psu.
I was asking if you had the chance to compare this one with the yellow PSU pcb discussed in this thread.
cariocaman85
To replace the acoustically humming power transformers, I ordered these ones, I think it is tight but hopefully they will fit in the alctron psu case.
