- Joined
- Feb 3, 2012
- Messages
- 73
So was I. My friend could be mistaken. I hate to spread rumors.
Inject an AC test signal right into the grid of the tube through a 50pF capacitor. You can disconnect the capsule as well. Depending on the tube, you should see around 6dB of gain from the grid of the tube to the output (2 to 3) on the output XLR.Is there any easy way to inject a test tone to measure the circuit to see if I can find the problem.
Check that the connections to the capsule are tight and check that the capsule is not collapsing.Hello All,
Having an issue with one of my two C12 clones which worked flawlessly for years.
One has anemic output, the other is normal.
Powered both up on the same power supply, cable.
Swapped tubes with no change, the problem did not follow the tube.
I would like to isolate the circuit from the capsule for testing. Is there any easy way to inject a test tone to measure the circuit to see if I can find the problem.
Great, I will give this a try. I wanted to test the circuit separately from the capsule before I went thereInject an AC test signal right into the grid of the tube through a 50pF capacitor. You can disconnect the capsule as well. Depending on the tube, you should see around 6dB of gain from the grid of the tube to the output (2 to 3) on the output XLR.
Will do Tim, both capsules are your great work and have sounded great aside from this issueCheck that the connections to the capsule are tight and check that the capsule is not collapsing.
Awesome, will have a lookYou can find a step-by-step testing I did while trying to troubleshoot a 251 I had built - starts here: ELA M251 Inspired Microphone - Build Thread
I just finished building my pair of Chunger Matador C12’s … with AMI T-14, NOS 6072a and MAIKU K-12 capsules (sorry, Tim … I can’t afford yours … YET … but as you have stated here previously, I can always upgrade!)I had #84, I believe it was, that I bought new. Sold it back in 2015 along with most all my gear.
Excellent mic all-around! However, no good at all for acoustic guitar in my experience. There, it’s way too dull!
If you can buy a pair for a fair-price, I wouldn’t hesitate. I haven’t heard anything about a supposed “safety-circuit” problem, but I never looked at the power supply. I know the CS1 is self-biased and use a single transistor buffer in its supply.
The capsule is a custom CK12-type, MBHO-manufactured and spec’d by David Bock of Bock Microphones. I’d find out for sure if the pair you’re considering are original capsules or Tim’s capsules… I wouldn’t hesitant with either, but I’d want to know for sure either way.
Lucas LMG-95-ES tube (made by Mullard), and labeled as such. AMI has replacements. Both sides are ran in parallel. There are arguments on whether other 9-pin tubes will work good-enough.
Super tiny, AMI T-1 transformer.
Dennis at AMI is super helpful and responsive. Don’t hesitate to ask him for any help!
I have a pair of CS-1 -inspired mics, made for me by Chris at Barbaric Amplification, with original tubes (bought from AMI when I still had the CS-1) and transformers (bought from AMI in 2020).
The bias point was chosen because it was the best for the 12ay7, not a 12at7. Will it work? Yes. Is it optimal? Maybe not. They are two different tubes. I say spring for a 12ay7.After letting it sit while for months while I've been sidetracked by project after project, I finally finished my C12!!! It's got an Advanced Audio AK-12 (although I'd love to put in a CT12 if Mr. Campbell ever offers them again) and it currently has a cheap JJ test tube in it but I got a NOS Mullard from Christian Whitmore that I'll put in this week. Even as it is it sounds amazing!
My only concern is that I can't quite get the bias down to -1v. The lowest I can get it is around -1.34. Is this ok or will it be a problem? I'm using a 12at7 so I don't know if that changes anything where the bias is concerned. The B+ is right where it should be at 120.
@DuBmastah I agree about getting a better guide for v 1.4 (or at least moving it to page 1). There are some pretty good pics of Chunger's prototype v1.4 build on page 93.
Thanks @chunger and @Matador for providing such an amazing DIY product and all the help putting it together!
And BeesneezThe bias point was chosen because it was the best for the 12ay7, not a 12at7. Will it work? Yes. Is it optimal? Maybe not. They are two different tubes. I say spring for a 12ay7.
That being said, good CK12 capsules are available for about 400-550 USD from MBHO (canford carries the KA1000) and OPR.
