Fraternal Twins
Apex 460 donors
The green one is
almost the complete Mini-Mod.
- 62V zener swap
- NOS RCA 12AT7
- 220pF cap across pins 1 & 9
- stock capsule
- stock x-fmr
- stock input cap (it's polyester, and I would have changed it to that anyway if it wasn't)
The purple one is the C12 board/parts kit from chunger.
This stuff drives me crazy. While checking the mic on the bench, I couldn't figure out why my polarizing voltages were WAY lower than they should be. Everything looked good until I tried to get a voltage on "the other side" of the resistors. I had 2.6V on the back plate and 30V on the rear diaphragm (110V input). I was at the point where I would start doing stupid things, so at midnight, I shut it down.
This morning it occurred to me.... I've never worked with resistor values this high before. I wonder... So I pulled the spec sheet for my multi-meter (Fluke 115), and wouldn't you know it, the input Z on it is spec'd at " >10M". So doing the math using the 10M input of my meter as the "other" resistor in the voltage divider...
10M / 260M = 0.038
0.038 * 60V = 2.3V - (measured 2.6 on the back plate, close enough)
10M / 40M = 0.25
0.25 * 110V = 28V - (measured 30V on the rear diaphragm, again, close enough)
So yup, the meter was indeed acting as the "other" resistor in the voltage divider.
Voltages around the tube are perfect, so I figured why not... there's nothing to blow up here. So I plugged it in, turned it on, and WOW!!! It works!!!
I don't know if this has been mentioned in the 150+ pages of this thread that proceed this, but don't forget about the input impedance of your meter. Most of the time it's high enough to stay out of the way. But here we are working with resistor values that are high enough where that input Z is actually low by comparison. If everything else checks out fine and you're still getting low voltage readings at these points, this may be why. Check the input specs on your meter, do the math. If your readings and the math are close, you're likely good.
ETA: Yeah, it's been mentioned before (I should use the search function more often). It occurred to me that instead of measuring to ground, measure across the resistors themselves. You should get zero volts (or something close enough to call it zero). If there's a short to ground or other bad connection, you'll have not zero.
As for the build itself:
- NOS RCA 6072
- stock x-fmr
- stock capsule (at the moment)
- stock resistor chain on the stock switch (it works, so I don't see the need to change it)
I did a quick spoken word recording with both. Being sent an identical signal from both mics, based on the visual EQ in my DAW, there is very little difference in the frequency response of the 2 mics. I can't wait to see how they compare when I put a better capsule in the C12.
