Opa Alice build noise floor
wamosjk
New member
Lyons, Ne
I just did my first build with an OPA Alice circuit with the hex board from JLI Electronics. It has the TSC1 capsule and the body is just one of those cheap u87 knockoffs from aliexpress. So my question is what is a typical noise floor for this build. I really dont have a frame of reference because all of my other mics are dynamics and I heard the OPA Alice circuit is supposed to be extremely quiet. Right now the self noise is faint but it is there and since this is my first build I just wanted to make sure that I don't have an issue somewhere that needs to be addressed. Here is a raw recording demonstrating the noise floor. I will link to the .wav files and also attach them to this post.
View attachment opa-alice-noise-floor.wav
As you can tell from the recording the noise floor is really faint but is there if you turn up the recording. Everything seems to be clean on the board as I cleaned it several times with 99% alcohol and a microfiber cloth. I also saw in the troubleshooting the following:
Scenario two: Noise. Our probable faulty functions for this one are wiring or a short of some kind to the shell. IfXLR_2 or XLR_3 is shorted to ground, you can have noise.This is caused by not enough supply current and running the operational amplifier below rated voltage. You canhear what this sounds like if you have the mic connected, and then turn phantom power off. As voltage drops, atsome point noise kicks in, then falls off as voltage completely goes away.
So I made a recording of me turning off the 48v power.
View attachment opa-alice-circuit-turning-48v-off.wav
This seem like it might be the issue but I'm not sure. So I just wanted to post on here to see if anyone has had any experiences and could point me in the right direction. Am I just being paranoid and the self noise is totally normal for this build or do I have an issue that needs to be addressed either in the circuit or the cheap shell its currently in? If you need more info let me know. Here are some images as well.
Edit: here is a recording of the sm58 with a mic booster at the same gain level.
View attachment sm58-noise-floor.wav
IMG_20240919_113604176_HDR.jpgIMG_20240919_113628477_HDR.jpgIMG_20240919_113647784.jpgIMG_20240919_113654781.jpg
Well, you need to share more "in wich context" details, like how much gain do you have at the preamp. The circuit is pretty low noise yes, but depending on how much gain are you using at the preamp, that noise will come up nevertheless. But in what context...meaning is the level at the preamp actual real scenario, or practical level, or are you testing @ 58+ db gain? if its the latter, then yeah, it might be normal....links to files don't work btw...
Im running through the tascam 1x2 hr interface and the knob is at 75%. The max gain on the interface is 58db. But if i plug in a shure sm58 i dont really hear the noise floor but its also a dynamic so it doesnt have a self noise. It should be noted that im on linux and on windows i can use less gain but my main computer that has dual boot to windows has like 9 fans so the fans make more noise than the noise floor of the mic. As far as the links they seem to be working fine for me. They are on google drive and i have it set so anyone can view them. I also attached the same files to the post as well so you can just view them that way.
Probably reasonable noise level. I assume you were not speaking very loudly, the timbre of your voice sounded like normal level for a close conversation. I have trouble guessing what that would translate to in SPL, but the noise floor was just audible at that gain setting.
Did you record the audio so you can get an idea of the SNR at that level?
How does the signal level from the SM58 compare to the condenser mic at the same gain level? Difference between signal level and noise floor is what you typically care about.
That doesn't really make sense unless there is software gain on the windows system or software attenuation on the linux system. If there is software gain on the Windows system the end result probably isn't very different, because that gain would bring up the level of the signal and the noise floor. If there is attenuation happening on your Linux system then that would be a disadvantage because increasing the preamp gain to make up for it would increase the preamp noise floor as well.
Understanding how to optimize your software settings is a side topic from the original question, so to answer that, the noise floor does not sound unexpectedly high to me. To get objective numbers would require a much more rigorous measurement setup, either an acoustic noise source of a known SPL, or a preamp with accurate gain settings and a way to measure the electrical noise level.
Ya for some reason linux just doesn't like this Tascam 1x2hr audio interface. I had a different interface and didn't have that problem with but that interface really sucked. I like this interface I just have to turn it up a little more on linux. It really never presented an issue (until now). The Tascam 1x2hr does have proprietary windows drivers but no linux drivers so there may be something they're doing there to boost the signal in windows.
So I made a recording with the noise floor of the sm58. I attached it to the original post. I also removed the links from the post and inserted the audio into the post (My first posts here and didn't see the insert button on the file attachment). I won't attach it here too just to save the site from duplicate uploads At first I just used the sm58 but since its a dynamic it was much quieter so I decided to just hook up my mic booster and when I do that the signals are relatively the same and the mic booster should introduce clean gain and not introduce any added noise. So there does seem to be some noise you can see the noise seems quite a bit less. Not sure if this seems normal or not because like I said all of my frame of referece is with dynamic mics so I never really had to deal with condenser self noise.
I did stick both samples in my DAW and then boosted the sm58 sample 6db and only listened to the quiet parts and they may be similiar in noise then so it might be that the self noise of the OPA Alice is right around where it needs to be.
I really just wanted to make sure I built the mic correctly and didn't have any issues that I need to address and everywhere says the OPA Alice circuit is really quiet (around 6db). So if I am getting any extra noise I would like to fix it. I was a bit concerned about the noise turning off the 48v power because in the troubleshooting it states.
So I'm not sure if that noise I posted is the noise they are talking about here. If so I may need to get a different body for it. But all that said the noise floor is pretty quiet and is much quieter than computer fan noise so its very workable.
I use a slightly different form of the OPA circuit. See here: https://www.jp137.com/lts/OPIC.43.pdf
The audio output on my circuit is single sided to help keep the noise to a minimum.
(The addition of the differential audio output in the commercial Alice OPA circuit will add an extra couple of dB to the noise floor).
The Equivalent Noise Level from that single sided design is around 3 dB(A) worse than my reference Rode NT1 microphone, which has a published noise figure of 4.5dB(A). The NT1 is considered to be a pretty low noise microphone.
Even including the extra couple of dB of noise added by the differential output of the 'Alice' circuit, it will still be classed as 'extremely low noise' according to Neumann's comments on THIS PAGE
HERE IS a short sample .wav file of the relative noise levels from a single sided and differential OPA circuit.
Both are refererenced to a -9dB tone. .... The mic capsule is not connected, and is replaced by a capacitor to connect the reference signal generator.
So this is only noise from the circuitry itself. .... As you can hear, there's not much in it!
... Plus wiring the capsule signal via the PCB itself (with zero attempt to mitigate anything) is... questionable to say the least, and may or may not add extraneous noise to begin with.
Check the alsamixer settings, perhaps the default is slightly attenuated for some reason. Unexpected differences in alsamixer settings between different interfaces is a relatively common occurrence (perhaps related to changes from default being saved to interface specific settings, so a new interface returns to defaults).
Depending on what audio server you are using (Linux has multiple available, Windows and MacOS just have one) there may be other places you need to double check, like pavucontrol.
Like I said, slightly off topic, but relevant to what you are trying to do because you need to control as many variables as possible to make valid comparisons.
That is mostly because after two decades Microsoft still does not include a standard USB2 audio class driver with Windows, the way MacOS and Linux (and derivatives Android and ChromeOS) do.
Problems with chassis usually show as power line related noise, and I do not hear a strong 50Hz or 60Hz component in the noise floor. There is nothing wrong with the mic body.
That is ultra simple to just check. Do you not own a voltmeter of any kind? Measure the voltage on pin 2 and pin 3, and at the zener diode (using pin 1 as the reference terminal). It would be really obvious if one of the output pins had a short to 0V.
The OPA1642 op-amp will run down to under 5V supply voltage, so you might not notice even if that did occur, so easiest to just check.
I don't think there is a way to download files from embedded links, is there? I was trying to think how to compare the files from the OP to the file from rog to compare. My initial impression is that maybe the JLI build is not quite as optimized as rogs's build, but it is not too much different than other condenser mics I have (which probably have a little more circuity due to pattern switching, switchable high-pass, etc.).
I also heard that the noise of this circuit board is very low and the sound is very clean. As a result, after using it, I just felt that the noise floor was a bit loud. The noise floor is much louder than the tubes I made myself. It cost me about a hundred Canadian dollars plus shipping and I was very disappointed.
