In the original circuit, the 1Gohm resistor coming from the gate is connected to the wiper of a 1meg trimpot that's in parallel with the source resistor (google for "Schoeps schematic). That gets tweaked for either max headroom or minimum distortion. @RuudNL has done more testing on that, and has concluded you can't achieve both at the same time.
When the depletion layer spans the width of the conduction channel, pinch-off is achieved and drain-to-source conduction stops. Pinch-off occurs at a particular reverse bias (VGS) of the gate–source junction. The pinch-off voltage (Vp) (also known as threshold voltage[7][8] or cut-off voltage[9][10][11]) varies considerably, even among devices of the same type. For example, VGS(off) for the Temic J202 device varies from −0.8 V to −4 V.[12] Typical values vary from −0.3 V to −10 V. (Confusingly, the term pinch-off voltage is also used to refer to the VDS value that separates the linear and saturation regions.[10][11])
To switch off an n-channel device requires a negative gate–source voltage (VGS). Conversely, to switch off a p-channel device requires positive VGS.
https://sound-au.com/articles/jfet-design.htmMaybe I should have been clearer. I have understood that purely measuring voltages or current is not the way to bias the JFET. In my previous comment I mentioned the voltages again because ccaudle rightly suggested it was incorrect/impossible (seems due to the inverted PNP). I am both trying to get the best sounding mic I can with this build as wel as LEARN. I asked a few times why no matter what resistance I set on source I could not manipulate the source voltage to be above 2.1V fully aware that it could be the wrong thing to do but wanting to understand this weird (to me) behavior. I did state that I will be using REW to properly bias the JFET but it doesn't mean it's not helpful and interesting to me to learn about the theory of the JFET design. Not trying to ignore your helpful suggestions or comments but I'm also responding to other people that have also suggested things to consider.
Alternatively if you connect the 1G resistor to source through a trimpot can adjust the base voltage (and therefore Vgs) without changing the source voltage.
In the second option of connecting the trimpot between the 1G resistor and source you're effectively increasing the base voltage right? Or is the base still held at 0V?
In addition to the already mentioned ease of trimming the operating point, it allows some FET's with very low Vgsoff, which would otherwise result in very low source voltage, to operate correctly.. If I understood that correctly my next question is what is the practical effect/advantage of one way over the other?
I have tried adjusting the source resistor although the pot I have is 1M so it's not ideal using it in parallel with the source resistor to ground.
Definitely, within limits of course (pentode region).Slightly off topic - when loaded with constant-currrent sources as in this design, are the FETs sort of self-biasing in a way, if the two FETs' IDSSs are well-matched?
Thanks for the crayon drawings apparently I needed them. I read all the material linked and still somehow managed to miss that obvious point. Back to the drawing board. However is my signal generator output reasonable and or what would you suggest is an appropriate input range to test for?That was my exact point; doodling on my phone is not my forte, so i was going to do that on the computer, but @abbey road d enfer - thanks for doing it![]()
