[quote author="Brian Roth"] ...I spend a lot of time doing stuff up in my CAD program (with dims, etc), yet my engraver and I can NOT find a common file format to translate my CAD into his "robots". Hence, double effort is required... in effect, Engraver John has to manually translate my drawings into "Mr. Roboto" files.[/quote]
Most CNC-machines uses G-code, a simple form of the Gerber language. If John's setup uses these, you can convert e.g. .DXF or .PLT files from your Corel or whatever into G-code by an interpreter like Master5 from Artsoft. Import .DXF with necessary settings and parameters, then export G-code.
Works fine for my setup..
Jakob E.
Jakob E.
