I was a big fan on rail to rail decoupling in da old days ... I didn't want to sully my nice clean earths with crap from the supply rails. Then I did a very comprehensive circuit analysis simulation of Power Amplifier performance which showed that
rail to ground decoupling was
essential for unconditional stability under all operating conditions.
Going back to OPAs, I found going back to
rail to ground from rail to rail made everything much
more predictable and explained some instances of having to take extra measures to ensure stability and
good thd.
OPAs are small power amplifiers.
An important finding was that you needed a bit of
resistance in the decoupling capacitance too so
small aluminium electrolytics are just the job. I like to use
1u or 10u near each OPA, bigger for better HF THD but
small size is important too. 100n films or ceramics aren't usually required but don't make things worse. So add what you like as long as you
don't leave out the electrolytics.
But when you decouple to to earth/ground, you have to be careful that the
crap on the supplies isn't coupled to your nice clean earths. I always define 2 separate nets;
clean and
dirty. Clean is used only for feedback & signal. These are only connected at the output of the 'box' and this is also the connection to the main PSU capacitor. ie star earthing.
This is complicated by some new chips that MUST have a 'clean' earth pin connected to something directly 'coupled' to the rails. eg THAT 1646
http://www.proaudiodesignforum.com/forum/php/viewtopic.php?f=6&t=464&p=5177&hilit=decoupling#p5177 but these are rare.
There are many disbelievers of star earths from the digital gurus who like earth planes. But probably the most useful advice is JR's ..
Earth/ground is not a fixed voltage but has resistance & inductance (even earth planes) so any currents flowing in it will induce voltages.
That's not to say, earth planes can't give good results but they have to be given the same careful consideration as a star earth system ie you have to know the exact path your currents are taking.
So my $0.02 ...
- decouple both rails to earth near each OPA
- use small Aluminium electrolytics
- think where your decoupled currents are going
