Anyone here ever try the tiny Pikatron Prowave K4000004 transformer? I vaguely recall seeing someone post that it sounded good, but I can't seem to track that one down.
Bravo! Congrats on the build!Have really enjoyed the build, great thread and can really hear a difference with the mic.
Just checking on how to correctly bias the FET.
Im using, JLI TSC-2 Capsule the LSK189 and have set Bias to 15.9v with meter.
Measuring between Drain (C9,C7 and R12 on ORS CCT with 36V Zener) and GND
What am I listening for and is a meter the best way.
Got a very very cheap scope and even cheaper wave generator, is that a better way to go?
Also feel there is some clipping (could be hearing aids) could that be the bias?
Still sounds great to my deaf old ears.
Too many years with headphones way to loud![]()
Correct.May be you could try a JFET with a higher IDSS. According to this tutorial from Chunger:
https://studio939.blogspot.com/2012/12/vintage-u87-circuit-clone-microphone.html
"As I understand it the higher IDSS JFETs will yield higher dynamic range before distortion, but the overall output level will be a bit lower than the lower IDSS ones."
So, if you use a JFET with low IDSS, the mic will have a higher ouput level, but lower dynamic range before distortion.
According to the tutorial, recommended IDSS values for the u87 circuit is from 8-12mA.
Regards!
HL
Quick question.
If I’m using a k87 capsule (isolated backplates) in cardioid only, do I need to connect both backplates together?
Since so far most ORS 87 builds have used capsules with non-insulated K67/870 style backplates and the results have been very good, logic tells us to bond the backplates together.Quick question.
Great info! ThanksSince so far most ORS 87 builds have used capsules with non-insulated K67/870 style backplates and the results have been very good, logic tells us to bond the backplates together.
On the other hand, I've personally had 50Hz hum issues with switch parts/bodies/buttons not connected to GND in the SP CS1 and when using the B2-Pro as a donor body (also with switch bodies not connected in the circuit)
My opinion is that any metal parts that are free, not connected, in the high impedance area or in close proximity can act as interference collector antennas.
So I always connect to GND the rear diaphragm and the rear backplate if it is isolated K87 style. Let's say that between isolated backplates (K87) we have a capacity of approximately 300pF.
By connecting the back to GND we do an additional high-frequency filtering of the polarization voltage and at the same time a better shielding of the capsule.
That is really excellent. Nice PCB's for that one! Very impressed.Great info! Thanks
It's actually a single dual diaphragm, isolated backplate k87 style capsule.Congratulations on your stereo mic. I don't know if it's me, but I think the plastic screw box sounded a bit "phasey" as you moved it back and forth. Are the capsules coincident?
Thinking that the chiseled headbasket is causing more of a null on the sides than a round headbasket would, so I'm planning to migrate this to a Studio Projects C1 body.Then it might be frequency cancellation as the sound travels from one side to the other.
Haven't really noticed a difference between 24v and 33v, but I'm fairly certain that all my PCB builds have been 33v, so that could be why.@Wordsushi
Are you building your mics with the 24v or 33v zener?
Noticed any difference?
Also how do you find the overall gain with your usual mic preamp?
the ORS has a lot of gain compared to the vintage 87…
I might try lowering the backplate voltage a little.
Using a higher voltage, so 33V Zenner, will get a bigger headroom, allows higher SPL before distortion.Haven't really noticed a difference between 24v and 33v, but I'm fairly certain that all my PCB builds have been 33v, so that could be why.
Gain overall is about the same as my u87ai. I have a couple that have lower gain, but I've just been pulling FETs out of a bag of them without testing first.
