OPEN SOURCE DIY Mic Project - ORS 87 - Stripped Down u87
The poured ground planes in the main board seems to be no worse compared to U87 ORS board(s). But needs to be measured properly some day. Benefit of the ground planes for the 60V board was expected, given that it operates at a frequency above 100 kHz.
I will share the full KiCad projects for anyone interested in using them. Gerber files (in .zip format) are included and are compatible with JLCPCB. When placing an order, ensure to remove the order number, as it may be printed in areas where I've removed the ground pour and silkscreen from high impedance zones.
The 60V board utilizes surface mount components, with 0805 packages as the smallest size, except for the LTC3290, which comes in an MSOP10 package. Due to its small size, it may be difficult to confirm proper soldering without magnification. I've exposed the solder mask on the bottom side and enlarged the via holes to facilitate soldering from beneath using a soldering iron.
For reference, EEVBlog describes a method for soldering the underside of chips like the LTC3290, which feature a bottom thermal pad/ground plane:
The U87 mini body used for the PCB: https://www.aliexpress.us/item/1005...ain.22.21ef1802SWOLj5&gatewayAdapt=4itemAdapt
... and UTM-transformer UTM0587, 0547f or 0547 (if you add the NFB capacitor 4-10 pF, C13 in the schematics attached)
Without the NFB capacitor, the microphone becomes more sensitive to tapping on the grill, and the sound level tends to clip, even on U87 ORS PCBs. I prefer the sound with the NFB capacitor in place (in U87 ORS), as it brings the simulated frequency response closer to that of the U87. Without it, the response is more like the U87AI. I haven't tried yet on my board.
After some testing, applying 60V to the capsule (instead of the previous 45-48V) seems to produce noticeable improvements, so it's worth considering.
Before using the attached project, double-check everything. For instance, C8 and C9 should be placed on the backside if large polyester/Vishay Sprague capacitors are used. The C5 polypropylene axial capacitor must be positioned as low as possible above the resistors, as shown in the picture. Ensure that no components exceed 11 mm in height on the board. The RV1 trimpot should have a side-mounted adjustment screw, not a top-mounted one, as the latter can interfere with the body shell.
NOTE: In the ltc3290_dc_v0 schematics, C6 should be rated > 60V. I used 4uF/100V. R6 should be 1M and not 10K. I suggest to use X7R or COG for all SMD capacitors (if too large or expensive, go for X7S).
... and regarding capsules I have used,
the "green" one suggested by @Papa Tango Charly
single: https://www.aliexpress.com/item/100...order_list.order_list_main.106.33061802FX8QDt
I have hard time to distinguish the sound from Vamisound's alleged Takstar CTS-2 (dual) capsule compared to the green one in the spoken word.
There is also dual version now: https://www.aliexpress.com/item/100...list_main.59.4cec1802nUOCL3#nav-specification
I have not tested dual yet but it will be interesting while I am waiting for Arienne's K87.
If Vamisound's capsule is Takstar CTS-2 and as it is considered to be in top 3 of K87 'replica', then the green one is a very good value for spoken word.
I have 797 Audio CY002 waiting to be installed and compared to Takstar and Arienne's.
While waiting I noticed the similarity in the picture to Takstar for this capsule so I felt an urge to get it too:
https://www.alibaba.com/product-det...spm=a2756.trade-list-buyer.0.0.34df76e9MmIcll
Getwin on Alibaba.com puts a pictures of a Taskar capsule then on the seconde picture you have an other brand with red wire. I have bought these capsule. JLI and Getwin sells the same capsules I have bought a both C12 and a K87 at Getwin Alibaba and JLI they are the same. They are not Taskar capsule. There C12 is very dark and the K67 is a bit sibilant and not very warm. Best
Thanks.
So these:
... could be JLI TSC-2?
https://www.jlielectronics.com/microphone-capsules/tsc-2/
Good cause I was curious about them as well but too expensive to import to EU directly from JLI.
Well the very capsule that looks exactly like Takstar CTS-2 (AND confirmed to be it) still eludes me.
The 60V board using the LTC3290 unfortunately introduces switching noise. I can hear it as clicks occurring about twice per second when I set the mic gain to about +60 - 70 dB.
I can't get more than 10.8V.
What are you measuring here? Voltage on the drain of Q1?
The very first thing to check is whether the pinout of the LSK189 FET you're using matches the PCB. TO-92 FETs use pretty much all 6 permutations of source, drain and gate.
I measured at pole and sgnl, is that correct?
That's not the information you need.
First, measure the voltage at the R14/R12/C10 junction (as referenced to ground). Next, measure the voltage at the R12/C7/C9/Q1 junction (again, referenced to ground). The second voltage should be roughly half the first voltage, and should be in the ballpark of 10 volts.
Edit: In case you were trying to measure the polarizing voltage between "pole" and "signal," you can't measure that with a standard DMM - the impedance is way too high. The voltage there can't be easily measured, but should be right around 48V, unless you messed something up.
R18, R19 are 2k2 Ohm resistors, not 2.2, it's an error on the label, not on the part number from Mouser.
So, If you ordered part 279-H42K2DZA from Mouser, it is ok as this is the right part, but if you placed your own 2.2 ohm resistor then you should replace them for 2k2 instead.
Regards!
I soldered a new pcb gnd and Q1 are 44.6V, do you think that's okay?
Which leg of Q1? None of them should have 44.6V on them.
The drain should be around 10 - 20 volts (depending on the zener and FET you used), the gate should be at near ground potential, and the source should be a few volts (~1.5 - 3V). If you really have 44.6V on one of the FET pins, something is very wrong.
Well, what could've happened when applying a 1-10meg resistance between the capsule bias voltage, and the JFET gate? 😬🤦🏻
[Spoilers - *bzt!*...]
I've done this now twice lately
and I can confirm that you see about 45v at the drain after that 😀 👩‍🍳🥘🍳 (the max voltage ratings don't seem to be a joke 🙈)
Oh, my. Can you elaborate? It looks like I was planning on making that mistake later this week.
Look through the dataaheet of any JFET, in the "Absolute maximum ratings" section.
After that, recall how a multimeter works, and some of their characteristics, and what measuring a voltage involves 😉
This is in the context of @mic test 's attempt of measuring the capsule bias voltage, by measuring between the "Pol" pad (where that voltage is present) and the "Sgnl" pad (which is the JFET gate, as it unfortunately happens in this case).
As a general rule, you should always measure from GROUND to the pin you're checking voltage on. 1) Because generally, voltages are referenced to ground, and 2) because then you won't be inadvertently introducing a higher voltage at that point through the meter.
If you measure JFET pin voltages relative to ground, nothing bad will happen. DO NOT measure JFET pins relative to B+.
(obviously, there are some situations where you really do want to read relative voltage between two points, but those situations are far less common, and you need to know what you're doing)
I don't know my way around and wanted to ask if it's all right
I measured here
... And that is exactly how you (most likely ) zapped your JFET.
The gate pin is "in the air", not connected to anything..? Any particular reason for that? The 1Gohm resistor that's supposed to be connected to it, is soldered on the board, i see.
Why would you have needed to measure the capsule bias voltage anyway, though?
I'm not surprised, if the JFET gate is completely floating. Is that still the same JFET from those measurements in the photos?
I connected it it is the second circuit in the first was everything soldered on the PCB
STOP PROBING ANYTHING ON THE JFET GATE!
It might help if you also read and understood other people's advice too:
As an aid to troubleshooting, here's some information about the ORS87-Plus testbed I built.
Schematic​
Here's the schematic with the component values used. The changes from the ORS87+ schematic were mostly to follow the original U87/U87A values more closely.
For testing, the U87's 'calibration input' arrangement was rigged up by replacing R15 with 560R + 6K8 in series, and the input wired to the midpoint. (I understand the V1.1 PCB has space for 2 resistors). I didn't implement a pad or bass-cut switch. Feedback capacitor C4 was 2.7pF, made by putting 5pF and 6pF caps in series.
To simulate a single cardioid K87-style capsule, there's a 47pF capacitor (Ccap) connected between the FD and BP inputs (the Neumann test procedure includes a fixture which does exactly this).
The BF256B JFET was chosen after a shootout (here) between various types: it's nearly the best by various measures, and cheap and readily available. Biasing the FET was done by adjusting trimmer R7 for minimum THD at the output, when fed with a 100mV, 1KHz sine wave at the calibration input. Values in blue are DC measurements at the bias point, and in red are the measured AC values.
The input stage looks like this:
Results​
Results are pretty close to the reported values for the U87A:
MeasurementValue
Overall gain, CAL to Vout, 1KHz (measured at 100mV in)-1.6dB (0.83x)
JFET open-loop gain (1KHz)+19dB (9.0x)
THD, 100mV RMS in, 1KHz0.013%
Max input voltage. THD < 0.5%, 1KHz (RMS)530mV
Drain current at optimum bias0.38mA
Polarization voltage45.0V
I also did a frequency response and distortion plot using REW. This is with a 100mV RMS input level.
We're getting a moderate 3-4dB dropoff at 15KHz, and a stronger rolloff after that. Obviously some of the distortion is coming from the transformer, which is relatively cheap compared to many alternatives.
    972.5 KB
    283.2 KB
