Opinions on different brands/series of capacitors in the audio path
migidee
I have read a lot about capacitors in the audio path on this site and others lately, and I have learned a ton.  Obviously there are the tangibles like ESR, temperature, etc.  but a lot of times specs dont directly translate to a better sound.  I know that an opinion is nothing but an opinion and not fact, but I know there is a lot of experience on this forum and I highly respect and value the opinions here.  I am curious of other peoples opinions on the price/performance of different caps.  For example:
Polypropylene
Wima mkp series= cheap, good price/performance with clear high freqs
Wima FKP series= more expensive,  Less audibly pleasing
Sprague orange drop= Used a lot in vintage gear, less hifi but a very musical, audibly pleasing sound
Polyester
Wima mks series= Cheaper than the mkp and fkp, good price/performance but not as hifi(clear) in the high freqs
Electrolytics
Panasonic FC series= built for audio applications, Clear/clean/detailed in the high freqs
Panasonic FM series= the same as above but a little cheper with less values available
Nichion He seies= similar to the FC
Nichion PW series= More lush(full) mid freqs, More musical sound
Phillips/BC= dont know much about the sound, but were used in vintage neve designs so are considered a good choice
Elna starget= tighter , more clear, transparent
Ceramic
brand?=  Generally frowned upon for audio applications for their track record.  It appears the type of dielectric matters a lot with these.  The general opinion appears to be go with the COG/NPO
Polystyrene
Brand?= Considered one of the best for audio at a premium price.  Used in vintage neve designs, described as bright, with a lot of high freq detail
Teflon
Brand?= Most expensive.  Considered the best for audio applications, clear and smoothh, but size of component may be limiting
Tantalum
Brand?= Do not appear to be a favorite of anyone in the audio path
However, I have heard of a lot of others that appear to be interesting and have not found a lot of info on.  And would love if anyone with experience with these could chime in with thier opininos, like:
Tropical fish?
Mustard caps?
Solen?
Hoveland?
Auricaps?
MIT?
Jensen PIO?
Russian PIO?
Mallory?
Cornell Dublier?
Mundorf?
Black Gates?
and any other brands you like?
here are some other good posts I found on the subject:
http://www.groupdiy.com/index.php?topic=7748.0
http://www.groupdiy.com/index.php?topic=36792.0
http://www.groupdiy.com/index.php?topic=35566.0
http://www.groupdiy.com/index.php?topic=42426.0
http://www.groupdiy.com/index.php?topic=23778.0
http://www.groupdiy.com/index.php?topic=6087.0
http://www.groupdiy.com/index.php?topic=744&highlight=pultec
http://www.groupdiy.com/index.php?topic=506.0
http://www.groupdiy.com/index.php?topic=2287
http://www.capacitors.com/picking_capacitors/pickcap.htm
http://www.groupdiy.com/index.php?topic=28779.0
Caps do not have a particular sound signature ('lush', 'fine mids', etc.) so ignore those who say they do.
Instead consider that they have electrical and electro-mechanical characteristics that you need to choose for your particular application. Experience suggests that Teflon and all of the Poly-type are fine, and that tantalum and cheap ceramic and not recommended. As for electrolytics, I've seen no problems when they have a bias voltage across them, but I think others might disagree.
Pass Labs, Naim, Bryston, EAR and many other long term hi-fi companies have used electrolytics in the direct signal loop and never had a problem with sales.
If you are going to send a lot of current through a cap (such as at the output of an amp) then that's a different challenge, and D. Self (in his amp design book) recommends a capacitance value way in excess of that calculated for frequency response alone.
read this
http://main.diycore.com/index.php?categories=Passive%20Components
All ceramics are not the same
