The X7R is probably a decent cap for PS decoupling but +/-15% capacitance change over temperature range makes it poor for timing circuits. It is worth mentioning that they do not even specify a voltage coefficient for that dielectric so obviously should never be used in filters or audio paths.I was taught X7R is well known for the phenomenon. I suppose now that you mention, I did just take their word for that. However, that bunch was pretty knowledgeable (Shure). I've personally seen lytics that 'THUNK' pretty bad when you tap them though. And cheap ceramics that flat just come apart. IDK.
I understand the rigors of sound reinforcement business.Physical construction. It's paramount for touring gear at any rate. Studio control rooms are much more forgiving.
Axial lead caps were more popular inside Peavey until we purchased a radial component insertion machine (coincidentally made by Panasonic). Radial caps are cheaper because of only one bung. Properly installed in a PCB the cap rests on the bung and then the leads get soldered. Over millions of components I have seen sundry issues but overall pretty reliable.Not the leads per se. Where they come thru the bottom tends to want to fail and leak, if I understand it correctly. It's kinda standard practice for radial Aluminum 'lytic caps on industrial stuff. The tall skinny cans in particular. They end up like they're 'standing' on their leads, all the weight of the can pushing down and the leads holding the weight but held immobile by the solder. Then comes the vibration and ...Uh OH!
With capacitors some are designed very specifically for how they fail. X and Y rated caps are designed for use on mains power (X across mains, Y hot to safety ground).True enough, but the different types tend to have their favorite way to fail. Like transistors: BJTs (and diodes) fail short, FETs fail open. It _can_ be whatever, it's just usually a certain mode for each.
Still learning... but caps are a mature technology... When we start dealing with SMD caps package size introduces a new variable.That particular fellow did come up during that period. I guess I'm not exactly immune to, shall we say... 'dogma' either when it comes to this stuff. Mostly I just try to copy stuff I've seen work reliably. Probably most designers do.
You can disagree all you like, I don't mind. You have, clearly, a vast experience that is at least somewhat different than mine. Prove me wrong, and I'll learn something. Questioning things and dialogue are how we learn things. Thanks for the great info amigo!![]()
