sonolink said:My3gger said:Solder 1k grid stopper resistors directly to E88CC pins, join their other ends and wire them to 1M/22n point. This is good general practice with tubes like this one.
If you turn tube sockets around, it is easy having power connections on the bottom, away from sensitive parts like grid inputs, which helps get lower noise and smaller current loop.
Like this? (see attachment)
Yes, like that, just solder resistors directly to two tube socket pins and leave the rest as it is on picture.
By redoing layout i meant board in the first place, where turret pins are. If you have HT at the top of turret board all sensitve parts need to cross it, which can mean troubles sometimes. Try to get it to bottom like in V72 and you will see there is no other way sometimes than turning (rotating) sockets 180 degrees.
Heater wires look fine to me.
Nice to hear that you want experiment with output and other things. Very rewarding
