Please excuse me for performing necromancy. I have some time to deal with this now and am not honestly stressed about it as I am in the could give a damn more over this right now. I just want to figure out why I get no output. Unless I hit certain pins on a T074!!!!
@Pusch31 you mentioned a picture of some software? Do you remember what you meant?
Yes, as far as I know, I was plugging into the correct TOSLINK ports. Mind you I also ran the ADA on its own using a TOSLINK cable as a jumper which everyone claims bypasses(in a sense) the ADAT converters. Use a cable as jumper and input 1-8 shows signal at output 1-8 respectively. Output is dead, well I’m getting sub volt electrical readings that fluctuate on what Input is doing.
At the time I pretty much gave up on being able to use the Behringer unit for any output. Input through the RME into the DAW works perfectly. Including testing it on the Focusrite Safire Pro24 which I was using until May’s Windows update would not see my 1394 card anymore.
Here is where I am at now.
Last night I pulled the top cover off and plugged the Behringer in and again decided to see if I’m running only half the transformer. Low and behold I was getting voltage to the output side of the unit. I couldn’t find the schematic Keith had drawn up and posted on my phone, so I pulled up a T074 data sheet and started seeing if any of the pins were actually receiving voltage. I did not write any of the readings down sadly, but I did get some output signal. On the T074 for channels 1 and 2, I first checked the pins 4&11 which power the IC. Pin 4 is +Vcc and pin 11 is -Vcc. When I touched the pins with my DMM probe, I did get an audible pop when the probe touched a pin. I had hooked up Channel 1 output to my Marshall practice amp. I was able to hear this but the practice amp was dimed both the pre and master volumes. The pops were not loud but noticeable. I checked all other output pins as well as the positive inputs. These would be pins 1,7,8,and 14. The positive input pins are pins 3,5,10, and 12. I got the same type of pop (similar to pop one gets plugging in a mic on a hot channel on a pa but not as loud obviously. I did not test the input negative pins and I did check the other Vcc+&- pins on the remaining 3 T074 if’s resulting in similar pops.
The main reason why I did not record the value content was that the pins are so small my attention was more focused on making sure I didn’t short the ic
So I am not sure where to go from here to get output.
I am under the impression that when the ADA8000 is used, inputs run into the A/D converter then into the TOSLINK output, to wherever the user decides to use the ADAT routes it. Upon a returning signal through the TOSLINK in(return), the signal is routed to match the input channel so essentially the Behringer unit is noting more than a type of Output send and return one would find on a larger kixing desk with a ADAT routing loop between the analog inputs and outputs. And, that my trying to use a pair of outputs as an audio out from the DAW is t going to work properly. At least not without an additional piece of hardware I will need to use to attach my powered monitors to. The Behringer unit isn’t designed to be used how I’ve been trying to use it.
