Hey guys,
I have a quick question…
I am working on the math to figure out some Panpots and I am unsure of something….
I am trying to determine the load of a pan circuit that is driving busses connected to a virtual ground summing circuit. I have a simple passive pan circuit with a dual pot slugged to create the law, 2.4k bus resistors and 12 channels - so the bus impedance is 200 ohms.
My question is this:
Is the bus resistor of the channel in question in series with the bus, or is it included in the parallel sum of the overall bus impedance.
ie - if i put one probe on one side of the pan pots output before the bus resistor and the other on the input of the virtual ground summing amp will i read 2.6k on the meter or 200 ohms?
I'm sure this is simple, but I'm just not sure and the difference between a 2600 ohm load and a 200 ohm load really changes things for the pan circuit.
thanks guys,
Timothy
thanks guys,
Timothy
