Stingray5funk
Member
Does anyone have plans for a pcb board for a passive di box that can use a transformer with pins
This is actually a good idea, and should be really quick and easy for anyone who knows how to design PCBs. Kinda like with the Bo Hansen PCB, make it so it can accept 2 or 3 transformers, and then just put input and output pins, and voila.Does anyone have plans for a pcb board for a passive di box that can use a transformer with pins
I would think a mix of low, mid, and high end (kinda like the Bo Hansen). For example I built a passive DI out of a Lundahl 1530 that I was fortunate enough to get for free. But I wired it point to point.which transformers would make a shortlist?
Not sure what Igor has that fits into this category.For folks in Europe, there is also UTM — but I haven't looked at what would be most suitable and can't tell if their listed prices include VAT or not... utmindustry.com
I think the point of a lot of this is so we don't have to buy from anyone.DIY Recording Equipment offers a kit with various trafo options. The kit includes connectors, a nice chassis, PCB, and trafo for between $60 and $150 total— a pretty good deal. If you ask nicely, Peterson may actually be able to provide parts a la carte, but I'm not sure he would do that. His PCB may be just the thing you need.
https://www.diyrecordingequipment.com/collections/studio-essentials/products/ferrite-di
Agreed.Vero doesn't do much good when the transformer's pins are spaced in a manner that doesn't fit the grid (I've actually toyed with the idea and the few trafos I tried didn't line up with the board at all.) I did a couple of DIs with the transformer upside down & secured with a zip tie run through a couple of holes in the side of the enclosure. They're ugly, and only for home use, but so far they've held up to my rather careless handling of them. A versatile pcb seems a much more elegant way to go though.
Send me a schematic of the DI that you want to build, along with a Parts List of >> ALL << of the parts that you want to use (MFG Part Numbers, datasheets, etc.) and I will come up with the stuff (i.e., various file formats) that you will need to either "etch-your-own" PCBs or to send to a PCB shop to have them made for you. It really ain't that hard to do, but I need to know -- WHAT -- it is that you want to use for your personal project here!!! I am....."Standing By".....Asking again, is this for people to make self-etch boards?
(which implies single-sided, no silk screening, no gerbers, etc, etc)
