Does anybody have a schematic for the Peavey VC/L2 or a guide/info on calibration?
So far the links I’ve found online for tech info are all expired etc.
I recently acquired one on Reverb and while it works/sounds quite good (especially on vocals and acoustic guitar) , the threshold ballistics are very different between the 2 channels, not to mention unity gain with no compression is with the gain almost off (7 o’clock) —which may be correct for this unit but seems odd to me, especially after years of using CL1bs and LA2a’s.
I've also noticed a low-end roll-off starting around 800hz and ending up 5db down at 100 hz and 10db down at 50hz --Again, this may be normal --it certainly doesn't sound thin --- but this is my first experience with this unit.
Thanks.
Thanks.
