letterbeacon said:I'm hoping to connect up the phantom PCB this weekend, but I wondered if I could run this by you:
I'm using a toroid transformer with dual 0-25VAC secondaries. I connect the two 25VAC leads to the two VAC inputs on the phantom PCB. I tie the two 0V leads together, but where should I connect those? At the star ground point in my pre amp that's connected to the chassis?
You need to connect the two 25VAC windings in series to give a single 50VAC. So connect the 25VAC of the first to the 0V of the second and take the 50VAC between the 0V of the first and the 50VAC of the second. Check with a meter on its AC range after you have done this that you do get 50VAC.
I'm using the 48VDC to connect to a JLM go between kit. Where shall I connect the 0VDC? Pin 1 of the XLR input?
Thanks for your help.
The 0VDC should go to pin 1 of the XLR input. This same pin 1 should also be connected directly to the chassis as close to the XLR as possible. The system 0V should be connected to the chassis at the power supply.
