OK, next one. Seriously, if someone cries "uncle", I'll stop. ;-)
This next board is somehow related to the giant ROM, as all circuit boards on both have a 6-digit number starting in 324. It has something for everybody on it, three form factors of transistors, round can and DIP chips, and HV pentodes. Googling the National Union tube number only comes up with military spare parts lists, described as "vacuum tube, pentode". The military is just so darn secretive. Does anybody have a clue what they might be? Anode cap, 7-pin miniature, 6V fil from pins 2-6, and I believe the G1 is pin 4, or maybe it is the cathode, if they are driving that from the chip. It doesn't match anything in any of the RCA receiving, or transmitting books here. Didn't look in any of the photo-multiplier books, but you never know, as the voltage is likely about right.
The anodes go to the boards on the right, each channel has 20+ 499K resistors in a string to ground, with the last one tapped to feed the first 709 (709's predated the 741) op amp. Some sort of active regulation. the first feeds the second 709, and that feeds the G-1 on the tube. The anodes also go to that oddball DB-25 housing plug.
Date codes range from 6915 on the Fairchild 709s, to 7249 on one of the DIPs. with that wide range, either a low-volume product, or from huge stockpiles of parts, as the military may require (and we pay for, but that's another post/rant).
Hmm, maybe this oddball thing really did run photo-multipliers for imaging, and the ROM contained missile directions to Ho Chi Minh's home address. ;-)
Just took another look, maybe it is cathode drive, there are small disc caps to pick up drive current spikes, this would work well to sense load signals, which would also include the possibility of Gieger Mueller tube loads. And six of them would be good to indicate the direction of the source.
To the CIA: Just kidding, this is really just a waffle maker. A simple waffle maker. Or a water heater. Nothing to see here.
Did this post get too verbose? I'm new here, just getting the feel of the place.
Gene
