maurizionatoli
Active member
Dear DIYers
I decided to write to you to ask for help on a project that got stuck:
following the advice of KingKorg (whom I respect and thank), I bought some prepolarized microphone capsules on Ali (I bought 10 of them) to be mounted in some wooden 35mm spheres that have to be set far from the amplifier unit, to minimize the acoustic effect of the mic body.
The project essentially consists of a buffer (active cable type) made in a round PCB (16mm diameter made in SMD) housed on the back of the capsule. This buffer will interface with a circuit (jfet as amplifier, BJT as buffer, transformer for balancing) which also takes care of lowering the voltage arriving at the amplifier circuit through an RC network (the last filtering stage, always RC , resides on the buffer).
The problem: the noise (ground noise) makes the circuit unusable, until I grip the outer ring of the capsule with my hands, effectively acting as a ground terminal. I checked with the continuity meter (buzzer) between XLR terminal 1 and all ground points, both buffer and amplifier, and everything seems fine, but the noise persists. Also checked that the voltages expected by the project arrive correctly in every point and everything seems OK (I thought that if there was a problem with the grounding "0" reference the voltages should not be right)
Can someone help me? Thank you in advance!
