Investigating noise some more :
And it depends very much on the primary termination.
Below 10K much less. Above 20K a lot more. O/C is the biggest.
And the higher the term, the more mid-freq hash picked up.
Looking again at my rack unit, powered down I have a loopback of -84dBu.
Powering up with no psu secondaries -58dBu
Powering up with everything but the heaters (no signal amp gain) -58dBu
Adding heaters so signal amp is giving 17dB of gain -41dBu
So it looks like I get a basic 26dB of noise from proximity and then 17dB for the 17dB of gain across the signal amp+output traffo.
I can confirm by placing the identical but disembodied transformer next to the rack installed one and showing that with 10K primary termination and the same Motu on the outputs, I getmore or less the same -84dBu with rack powered off and -58dBu with power on.
So : what I'll do now is rebias the signal amp for less current, redo the gain and noise measurements then try some other output transformers : first the Sowter and then an Edcor XSM. I can adjust the gain more or less with the bias to try to get as like to like gains as I can.
In a clean system, 17dB of gain can give less then that much added SPL noisefloor, but with a dirty floor that's what you expect. Like added for like and sometimes even more.
By way of comparison, my original Poorman which uses the same PSU and the XSM has a unity gain noise floor of around -80dBu and around 72dBu with 14dB of added signal amp gain.
