Thanks guys - the encouragement helps when one thinks it's all gone to the dogs.
I've been rebuttoning up the signal amp and now have it back where it was, running higer currents and so on.
Right now, I have signal amp net gain of 16dB and have incurred noise floor worsening of around 10dB, spl 20-20K.
It's not too bad but I'm hoping that's the worst of it.
Right now, with a 'perfect' input signal, the noise floor is completely independent of the input t-pad attenuator setting.
That will change when I feed it with a real world signal that already has it's own levels of mains harmonics noise.
I'll be spending more time to see if I can find improvements but I'm pretty sure that's where it is at.
Most of it is coming from the UTC, but of course, one expects a rising noise floor as one adds gain.
Things that makes quite a difference are :
- the output transformer secondary termination
- input transformer secondary balancing network termination
The other thing I noticed was removing pairs of GR tubes worsened the noise floor even as gain was reduced.
ie. 1 pair of tubes and noise floor was worst even though gain was least
Adding pairs reduced noise floor even as gain was increased
All related to the impedance of the combined triode-connected plates decreasing as pairs are added I suppose.
I guesstimate the plates are probably something like 4K or so, so 4 in parallel is 1K or so. (in the 'idle' case)
The 600R terminating means 8K plate-to-plate or 4K each phase (class A). So connecting 1K to 4K which is better than connecting 4K to 4K.
Or something like that ;D
The output transformer loading at 600R is my default setting. Decreasing the loading of the traffo by increasing the terminating resistance increases the gain and therefore also worsens the noise floor.
There is something like 3.5dB increase in net gain going from 600R to 10K and higher. That does also incur about the same in noise floor worsening. At this point, I'm leaving the 600R as is; later on I wiill revisit when I get further down the testing track.
The input traffo balancing network which is required as I have no winding CT on the hi-Z side (and no knowledge of inductance and resistance as yet), plays a big role in loading down the input side of the signal amp.
In general, I would expect that a termination value similar to the spec'd 'typical use' impedance of 15K is the ballpark way to go.
Too low a value and the input traffo secondary appears too heavy a load and the input signal is attenuated. Not to mention that the CV is also kind of attenuated by the heavy load (light resistance).
Too high and the noise at the grids, which is reasonably high (around 1.5mVpp) from EM into the UTC worsens the noise floor more than the increased input level provides. Normally one would expect higher grid-ground resistances. With 4 pairs of grids, that is probably reduced I suppose.
I did compare the results of lower and higher, taking into account the gains achieved and noise measured, and for now, I conclude that lower is better subject to maintaining the CV. Again, I will be examining this more as I get further on.
So, given I am deviating a long, long way from the original, for many, many reasons, the thing is to decide what gain staging to run throughout the signal amp. Not to mention the setting of the 'idle' bias and current.
Things to consider are in deciding what gain to run relate to :
- amount of GR I want to achieve vs the limit of acceptable noise floor
ie. tradeoff of output level for amount of GR limited by noise
- how hot of an input applied vs 'overdriving' the grids in the 'no GR' case
ie. tradeoff of 'no GR' distortion for 'deep GR' level achievable
All this stuff happening at once so a balance is needed across all of these. My knowledge is pretty slim in reality, but I'm gradually getting an intuitive feel of all the competing things - which is a bit part of the motivation for experimenting
Anyway, onwards and upwards. I do think I have a worst case performance now which is acceptable.
Things are significantly better than they were a couple of weeks ago
