Starting to 'come together' now - literally.
One useful thing to do is to take the readings, graph it and before switching tubes, re-measure any slight anomalies in the curve. There are the occasional reading which doesn't settle as quickly and can cause a bit of ripple in the curve.
As long as the reading is done at the same measurement session, it will be accurate.
I found in needed to recheck a value or two here and there.
The overall session-session repeatability seems to hold at max of 0.1mA at the 'big end' of the current scale.
ie. 0.1mA in 9mA. At the small end of the scale, it is more like 0.01 in 1mA and quite a bit less.
The spread so far is around 0.8mA at the 'big end' of current (9mA or so) and 0.3mA at the 'mid end' of -30V grid. They all converge from -40V to cutoff at -60V.
The 'eliminates' were more like 3mA out of the spread at the top end.
Just finishing up my first cluster of 8. I'll put that one up then do my next cluster of 8.
The cluster 1 and 2 mean values vary by around 0.7mA. The spread of each is about the same.
So far I think I'm getting a reasonable tolerance - should get 2 fair groups of 8 from 20.
I would say 25 tubes would have made a significant difference, allowing removal of another outrider or two in each set.
Seems to me like 1 in 5 is a large outrider, another in 5 a smaller outrider - so 3 in 5 from a min sample of 25 will give 2 good sets of 8. OK? ;D To be a total d**k, look for one set of 8 in 30.
After a couple of sessions of this, and as a 'first time' observer, I can say I am truly amazed as to the repeatability and accuracy of these tubes.
Even down to measurements of <10uA the stability is pretty solid, once warmed up for 20mins or so.
I expected them to 'dance' around alot more - not so *at all*.
I think doing measurements like these could yield a pretty startling matched set of 8 from 30.
Mine are a little looser than that on this set of 8 of 16 (4 eliminated from 20). Don't think I can improve this given my sample size. I have 1 or 2 outriders within the set if 8 which drag it down - the other 6 are very close.
But by arranging hi-lo pairs I can average the differences down. Can do that either within a phase or across phases - I'll look at both.
However, the differences here are pretty small in reality. I don't know how tubes age and I don't know at what point of 'imbalance' the distortion components vary to any significant degree.
From my observations with the 'balance' pot at 'idle' (which is the high current mark where the errors are highest and have most 'puisaance'), the relative amplitudes of the odd-even harmonic distortion sets *did* flip in dominance pretty easily, but I don't think the overall THD raised or lowered all that much with balance.
But I'll find out more soon enough.
(Then of course, there is variations due to temperature, line voltage fluctuation and so on !)
Now to be taking a break please. I have another 8 to do
Tomorrow
