mikeyB said:Hi Ian - can the poorman make up amp be used with a standard pultec filter network - ie 600ohm.
someone is asking me if i can convert a diy chip amp to a tube output, but want to leave the filter circuit (based on the original) intact.
Will the tube makeup circuit work ok with the original filter impedance?
Thanks in advance![]()
Yes, this should be possible. The poor man's tube gain make up (PMTGMU) has a very high input impedance so it will not load the filter. Does the chip amp circuit include the interstage transformer in the original EQP1A or not? Do you have a schematic available?
