ilfungo said:Thanks Ian
yes the pot slide is connected to the top of 47uf cap.
Sorry I'm not an expert :
"Loss of low frequency usually means the EQ is loaded too much" ?
Can you explain what could be?
I'm using a this circuit with Carnhill 2281...
The output of the EQ needs a gain make up amplifier. This needs to have a high impedance input;preferably at least 470K. If it is much lower than this it loads the output of the EQ too much which results in loss of bass response.
It is not deigned to be fed directly to a transformer, Check out the documentation in the PMEQP1A folder under the DIY tab of my web site:
http://www.customtubeconsoles.com/diy
