MatthisD said:Hi again, I'd just like to ask if the PSU can handle anymore than 2x 6cg7 with the right transformer?
Yes, you just need to adjust the series resistors to maintain about 10V drop across each. If you add many more 6CG7 stages you may need to increase the capacitor values too. In my mixer, which has 16x 6CG7 and 2x ECC99, I use 100 ohm resistors and 470uF caps. You do have to watch the inrush current into the first resistor when the supply first turns on. In my mixer supply I use a 5W part for this.
Also, will a 10k/600ohm output transformer enable this to drive 600ohm loads without the adjustments mentioned a few posts earlier?
Yes, but the headroom will not be that great. The 6CG7 stage will do about 20V rms into 10K which via a10K:600 transformer is only 5V rms or +16dBu. If you really want to drive a 10K:600 transformer I would recommend using an ECC99 as an SRPP at 15mA (you can do this on the same PCB) and this will do +22dBu into 600 ohms. In both cases you do lose 12dB of gain in the transformer of course.
one more...with the EQ input impedance being 10k could I take the signal from the output of one gain stage straight to the EQ input?
Yes, that is exactly what I intend to do in mixers using the poor man's EQP1A!
I suppose what I'm aiming at is a one-bottle type mic preamp with PM Pultec/gain makeup.
cheers
Matt
Sound like a cracking project to me.
