So Far I am resisting attempts to add new things. The 'unrealistic' ones are probably already catered fro in my Mark 3 design which is a different beast entirelyTubetec said:Wow, the wish lists are getting longer and more unrealistic by the moment![]()
That is basically how my HPFs work. Two series caps and two Rs to ground for 12dB/octave. Second R is usually the channel 10K fader. Simple 3 position selects one of two frequencies and third position shorts out caps for flat response.For me usually the first treatment I reach for is to trim the bass end ,per channel , very often a good balance can be found with careful mic selection and a touch of low cut filter. I also found with some of my experiments that relatively simple circuits with switched values of coupling capacitor and relatively shallow curves worked adequately for most HPF jobs .
