I remember seeing an interview with Rupert Neve, initially he was very suspicious of Smpsu's ,he didnt see the logic of essentially using a noisemaking circuit to create his supply rails ,Ive been hanging on the sceptical side of the fence in this regard also .
I guess if your switcher circuits are nicely sheilded in aluminium ,spurious rf radiation is minimised and no need for exotic mu metal sheilds.
Longevity is the other question ,we do know that a conservatively rated old style supply can live 50 years or more ,I guess de-rating your smpsu's will help alot in this regard ,but still, long term stability is a bit of an unknown .
I see in some of the better high end regulated supplies ,as in my studer C37, theres always low ohm series resistance in the heater circuits ,presumably this limits inrush current when powered on from cold , cold heaters are only a fraction of the resistance of warmed ones .
A little higher voltage and dropping resistors might play out better in the long term for smpsu's for heater supply ,both for the valves and the supply itself.
