Brian Roth
Dammit all I ask is for the conversations not degenerate into snippy crap. Of course, we'll hear this nonsense....Go take a hike
Bri
It took awhile before the preacher didn't worry about truckers breaking into the sermon. I learned a LOT, circa 1974.and how long did it take for you to get rid of the CB issue? Did you learned anything about that experience?
No. Because it simply doesn't. The load doesn't change how the connection is balanced.Obviously you don't know the 150 resistor keeps the cable in balanced connection.
At the cost of introducing some of its own noise, and amplifying whatever noise remains on the line. Balancing is never perfect, there is always residual noise. Ensuring that the nominal line level is high guarantees good noise performance.After that, the op amp in this case makes the gain in the monitor,
Are you aware that it depends on the level that is sent to the line?And the coarse contour in the adjustment observed at the big knob is gone. Because barely moving the gain at the monitor controller was instant blast at the lowest volume setting at the monitor.
100% mumbo jumbo.There is one definition to 'balanced operation' that cover four types of circuits, which three of them are coupling connections from one device to another, and one is a circuit topology.
Different coupling and output circuitry require different approaches to establish balanced operation. In the case of the Mackie big knob, which is called impedance balanced or suds-balanced has one rule on connection, while transformer balanced has another, As so does electrically balanced.
But if the correct approach is applied balanced operation is established.
A droplet of fact in an ocean of BS.The definition of balanced operation is a differential signal path that rejects common mode noise.
wiki said:In an electrical system, a ground loop or earth loop occurs when two points of a circuit are intended to have the same ground reference potential but instead have a different potential between them. This is typically caused when enough current is flowing in the connection between the two ground points to produce a voltage drop and cause two points to be at different potentials.
Brian... being an old member does not give you license to be uncivil to drtecho he deserves the same civility we demand from him.So, Doctor.......you say you know EVERYTHING....
How many successful desks have you designed/built? How many successful studios? How many video production rooms?
Dammit, I need to get to bed. I have REAL stuff to do later this day besidesdoing a Dick Measuring process.
he was last seen online about an hour ago... don't poke the bear.And....... Dr Techno has left the building! Or did you take him out John?
I missed a few days of this thread. I see you have been Dr Techno'd. I came across him a year or so ago on GS and his grasp of reality then was tenuous at best.
It appears that he was last active on GS back in 2018.... (time flies)I missed a few days of this thread. I see you have been Dr Techno'd. I came across him a year or so ago on GS and his grasp of reality then was tenuous at best.
lets try to be graciousCheers
I was curious, so I just looked at The Doctor's profile again. Now sez zero posts. Guess he deleted his comments....which will make this thread confusing for anyone reading in the future.
