radardoug
Hey Bri, you were just calling him out, and for good reason. Hope you are having a good Xmas apart from that!
A simple explanation of why it's best to choose the output end shield connection while lifting the destination (input) shield end is that amplification often takes place at an input. If the "telescoped" shield is connected there, the noise it is trying to take to Earth joins the grounding path of the input circuitry and dirties up the amplifying input stage. I think Bill Whitlock alludes to this in his detailed papers. Thomas Hay at MCI dicusses this in detail in the Nov 1982 issue of db magazine and in a paper delivered at the AES convention around that time.You obviously did not read or at least did not understand the material. The point was that if you only connect one end (no disagreement that connection at one end only is fine for low frequency shielding, the only issue is RF performance), the proper connection point for the shield is at the output end, not the input end.
I forgot to mention, in those papers on studio grounding they point out putting balanced and any unbalanced gear you have into separate racks, and of course routing separate conduits for mic, line, power, digital, and telephone line signals. The earlier post from midnight arrakis is spot on about using balanced power if you can swing it.A simple explanation of why it's best to choose the output end shield connection while lifting the destination (input) shield end is that amplification often takes place at an input. If the "telescoped" shield is connected there, the noise it is trying to take to Earth joins the grounding path of the input circuitry and dirties up the amplifying input stage. I think Bill Whitlock alludes to this in his detailed papers. Thomas Hay at MCI dicusses this in detail in the Nov 1982 issue of db magazine and in a paper delivered at the AES convention around that time.
And the next post #39 is spot on about why balanced power is useless in the case of balanced equipment/connections.The earlier post from midnight arrakis is spot on about using balanced power if you can swing it.
I had a client in LA that was building an immersive studio, and was quoted $150K for a balanced power system. He called me in a panic and I explained to his current electrician how to wire the studio, and then ordered him a 10KVA 220V to 110V transformer for $2K, had the electrician jump the phases together in the panel and he has never had a micron of noise in his studio. Not balanced, just isolated. When I worked for Record Plant Remote, we had the same thing. Every outlet was on one phase. Never had an issue. Balanced power involves grounding the center of a transformer, which makes no sense to me, accept it eliminates grounding problems that should be resolved correctly.Nah, balanced power makes very little difference.
Yep, free balanced power in the US if you run everything at 220VAC. A well known mastering studio does this. If there is a piece of gear that won’t operate at 220 they have AC step down boxes for that individual piece. There are giant isolation transformers at the mains entrance too.Actually, there is "balanced power" at the ready. In my NOLA flat, the range is connected to the 230V that jumps the two phases.
Rewiring the whole studio is another possibility with adequate plugs of course. Most of modern equipment is capable of 115/230V operation.
One would need to reatin 115V outlets for itinerant gear.
I would not advocate anyway, just erring.
This is a minor semantic point but the two polarities of 120V in residential mains power drops are considered the same single phase, in mains power parlance. Indeed the two legs of 230V power are opposite polarity. In the US multiple phases refer to single phase or three phase distribution. The three (actually four) separate wires on high power poles are carrying three different phases of power.Actually, there is "balanced power" at the ready. In my NOLA flat, the range is connected to the 230V that jumps the two phases.
OK. We have a similar distinction here, with two legs of 115V 180° apart called "diphasé" and anything with a different angle called "biphasé". Last time I saw "diphasé" was in 1976.This is a minor semantic point but the two polarities of 120V in residential mains power drops are considered the same single phase, in mains power parlance.
Lacking reference here. Does it refers to 115V balanced power being potentially less lethal than 115V unbalanced?Studios wired for 230V outlets kind of defeats the lower (only 60VAC) benefit promised by "balanced" power.![]()
I am not familiar with that nomenclature.OK. We have a similar distinction here, with two legs of 115V 180° apart called "diphasé" and anything with a different angle called "biphasé". Last time I saw "diphasé" was in 1976.
In my judgement it's a good on paper marketing concept. Promoted for lower noise, not human safety.Lacking reference here. Does it refers to 115V balanced power being potentially less lethal than 115V unbalanced?
I have never seen or heard of anyone being seriously hurt by electrocution in a studio wired according to EU standards.
Same is not true for some live systems.
[So what is the theory behind 'balanced power'?] -- See Post #38.So what is the theory behind 'balanced power'?
That would possibly be the case for equipment with a pin 1 problem. The common mode to differential mode conversion I was describing from the figure in the Whitlock paper occurs even with properly designed equipment due to the physics of shielded cable.the noise it is trying to take to Earth joins the grounding path of the input circuitry and dirties up the amplifying input stage.
(a) to reduce the amount of current injected by the connected equipment into mains ground (e.g. via 'class Y' capacitors)
(b) reduce common-mode noise
(c) minimize the electrostatic field in the vicinity of the mains cable,
Have you noticed that this member, who decided to leave on his own volition, did not show any respect, and wrote a lot of misinformation?Now that you have so effectively driven away one member of the forum (which of course none of you will be sorry) in these days of exchange and mutual respect,
I'd be curious to know what kind of set-up and what environment necessitated such extreme precautions.I would just like to say, as I often do here, that I have used balanced power very successfully on several occasions. Of course, I did not create expensive black magic from it, but implemented it in cases where I had already installed an isolation transformer.
Why are you hiding behind your native language? This sentence translates very well in english, although it's often used in reverse, with the tree hiding the forest.Tako je to kad se od šume ne vidi drvo.
