Hello,
Thanks, Johan.
I read your post, actually several times
Read it again, had a good night's sleep and tried different resistor values across the secondary of the isolated TX yesteray. Then I figured that it (a real cheeseburger-priced-but-doesn't-have-a-name-printed-on-it TX, and most probably an insult to the entire circuit
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
may need a resistor across the primary. Tried it and and it flattened out the sharp fq rise that I had before (had used it at one point in tracking as a natural exciter -- haha, eh?). Test square wave (1000 Hz) in Visual Analyzer looks fairly good too (for that no-name thingy, that is). However, it also gives me a slight high fq roll-off starting at 12Khz to -2.5db at 20Khz (maybe not a bad thing for tracking) and an overall drop of 2.5db in volume as well, hmm. I'm learning here. Need to test with TX in circuit next, and might try a Zobel network (resistor plus capacitor) for better results...
Zobels are explained in this thread: "Damping Transistor Ringing" (Zobels):
[http://www.groupdiy.com/index.php?topic=32441.0]
A true hardcore read, but very interesting. Not sure though it can be done with RMAA and Visual Analyzer only.
And thanks, Sleeper.
I read about your mod, as well as the "bluebird" one elsewhere, many times too
Sounds very promising and I have had a look at the UA175/176 schematics already (mod scheduled for the future or second unit). And thanks for sharing the TX serial numbers, as I don't usually have TXs lying around. Too bad you don't have the free RMMA softo (WIN only, I think) for measuring
Happy so far, since the unit is off the shelf again
Script
