I think some people think that linear supplies are somehow better than switching mode supplies but if done correctly, SMPS can be very quiet. And SMPS have so many other benefits, I don't know why anyone would use anything else. You can get off-the-shelf AC/DC SMPS modules that are very small and efficient. For an SMPS 25A is easy whereas for a linear supply you have to be careful or something could start smoking.
The PSU that I'm using right now is a few MeanWell AC/DC SMPS, some large, high-Henry common mode chokes and filter caps (which can be relatively small compared to a linear supply BTW) in an external 1U rack enclosure and then at the remote end I have the usual regulation to get the desired voltages.
I just tested a simple API style mic pre and the noise floor is very good. There's maybe a little hash in the 15KHz range but at a level that is totally inconsequential (-110 dB after 40dB gain).
