More positive news on that. It does seem likely to be down to an electrical issue with some of the panel switches. There's a square opening at the rear of each one, so I blasted in some plastic-safe Home Depot contact cleaner someone recommended here, to get the mechanics functioning again, and the whole unit magically came back to life, meters and all. When I got home later tonight, the voltage doubler switches for each channel had sort of gummed back up and it was back to doing the "drop the voltage when a load is connected" thing. Tried to clean them again, but they reverted to "gunk mode" faster this time. They probably need to be removed and cleaned more thoroughly (or disassembled).
Bruce- They don't look that uncommon inside. The more well behaved two look like DPDT, but the voltage ones are those multi-pole types with a whole row of pins on each side. The footprints look like lots of stuff I've seen, so unless the switch caps or the pinning is some oddball stuff, I may be able to swap something else in there.
Question: Anybody know how to remove those banana/screw terminal combo jacks on the front without desoldering. They're the type that stops when you unscrew it far enough out, so the thumbscrew part doesn't come off.
