OK, were starting to get close to this thang. I see from the owners manual that you can't have cut and boost enabled at the same time on the mp. This means that they are indeed, sharing the cap/inductor filters. Of course! Otherwise, you would have to have 4 times 11 =44 caps/44 inductors, then double that for having the capability to cut and boost at the same time, this means 88 caps/inductors! And it's stereo, so that means 176 cap/inductor combos!
So, they must be switching the cap/inductor filters between cut and boost. This means I don't have to compute seperate values for the cut bell curves! Yipee!
But, in order to get symetrical curves on the cut/boost section, you have to trim the q on the mid cut for every band/frequency. No biggy. I got pretty close, check it out. This is the same cap/inductor combo used for both cut and boost. The cut has a 200 ohm Q trimmer in series with the LC circuit, the boost does not need it. You can leave out the Q trimmer if you want a steeper cut curve than boost.
I lucked out by choosing 1056 ohms as a reactance constant for the filters. IT GAVE ME 90 PERCENT STANDARD VALUES FOR ALL THE CAPS!
The inductors can be wound for any value you want.
:guinness: :guinness: :guinness:
I see that making a balanced filter type eq would be insane, as you would need ten thousand dollrs worth of caps and coils. But, I think I am going to use nalanced makeup amps on this thing. This means a couple of extra push/pull x-formers, but we need to get the noise down. I think the stock EQP-1A makeup amps sound great.
