Klaus Mogensen
Active member
Damn, maybe i'll build the slowblow with the G9 PSU. That seems fairly straight forward.
Thanks for the answer.
I see, the modular approach. Should work fine.I, however, don't have much rack space, so I'm getting more and more keen on the idea of using the slowblow and making the unit so it can also be used as a normal microphone amplifier (using a Lundahl 1538xl input transformer).
If your source can deliver it. The most easy ways out are (as been suggested somewhere here before): (1) by means of input-TX-ratio or (2) simple preceeding 553X-stage with 600 Ohm build-out-resistance.Then maybe also with the option of swicthing some of the eq boards in between the two gain stages for tracking, if this is possible considering the low input impedance of the eq boards.
