The bandwidth pot on a Pultec is 2K5, so 10% of this value (the tolerence of
the original AB pot) is 250 ohms, so, even a 20% disparity DCR on the
inductor would only be about 6 ohms at the highest DCR value.
The DCR is only important when verifying that an inductor was correctly
reverse engineered, because it's one parameter (of many) that could indicate
when an inductor has been wound differently than the one you're trying to
copy. A wrong DCR reading can indicate other parameters (that affect the
sound of the inductor) are different than the inductor that you're trying to
copy.
The lower or higher inductance just requires a cap value adjustment. One which
you'll need anyways, as your inductance values don't look like Pultec values
anyway.
If you're trying to make a copy of a Pultec inductor, the DCR, as a
clue, could be more important than the inductance.
copy.
anyway.
