TomWaterman
Hey folks,
After a bit of reading and searching the web I found this schemo for Pavel Macura's discrete class-a push-pull follower based on the Hiraga stuff:
I am looking at the topology and its gonna take a while to sink in...however I'm looking for some application specific pointers.
I would like to use this style of follower as an output stage driving a 600ohm trafo - it appears in essence to be great for this (albiet a touch OTT!! as it stands) with low THD / IMD and ample current drive, plus I like the fact it uses garden variety BJTs.
I understand its unity gain but was wondering what would be the easiest way to add gain to it? Ideally I'd like a stage that does either unity or +10dB gain so it can be fed from a fader and be a booster output amp.
However it would need severe down scaling to improve efficiency.
As it stands the stage eats current to drive 8ohm speakers @ >1A. I'm still trying to figure out this discrete stuff and the way this stage is biased, however I'd like to keep max current draw to 50mA and still chuck decent level into 600ohm.
If I understand this right (forgive my innocence):
16V RMS would be +24dB, into 600ohm
16/600 = 27mA
Power = approx 0.5W
So 40-50mA would be plenty to maintain class-a into 600ohm with power @ 1-1.5W
What do you reckon - could this stage work well with a re-bias? Maybe Q5 & Q6 can be BD139 as well?
Cheers Tom
![hiramp.gif](https://proxy.imagearchive.com/ebb/ebb8a329bbadbfda72ac413b140141a2.gif)
16/600 = 27mA
Power = approx 0.5W
Cheers Tom
