Has anyone found a 1000uf,50v with a package size 10-11mm dia for C8, all I can find is a 12.5mm, won't fit properly on the pcb, the space layout is too small.Thanks for the reply
This might help, from the errata/build notes:Has anyone found a 1000uf,50v with a package size 10-11mm dia for C8, all I can find is a 12.5mm, won't fit properly on the pcb, the space layout is too small.
Thanks JMan for the heads up on C10,This might help, from the errata/build notes:
Capacitor Orientation – C10 has 2 “+” markings on the board. Correct orientation, “+” is to the right . C8 doesn’t leave much room for mounting. This cap may be added to the underside of the board if you have large standoffs for board mounting or sat up high above C11 and C10 for shorter standoffs.
Sure!Thanks JMan for the heads up on C10,
Maybe I will just use insulated wire to the pcb, and have C8 strapped to the chassis.
It does take a lot of time as it is not a well put together build. I've read all of this thread and it started as almost a collective build and figure it out as you go. The setup procedure is not very clear or definitive. I'm never really sure about the chip based oscillator and meter setup and would love it if someone could post on how to make a traditional one. Some other guy on this forum sells his version of the PYE. They came after this build so probably used a lot of ground work covered here but they don't share the winding / core information. Apart to say it can be easily built.I hope this jumping into this build project was a mistake, doesn't seem like there is much action here anymore.
I feel your comments, I am in the beginning build phase, just received the pcb's from collective cases, but the chassis and face are back ordered. I will use the Cinemag CML1-15 for the input transformer, and the EDCOR WSM600/15k for the output transformer, and the EDCOR XSM600/10k for the sidechain as per the org BOM. it seems like the output transformer should be reversed 15k/600?It does take a lot of time as it is not a well put together build. I've read all of this thread and it started as almost a collective build and figure it out as you go. The setup procedure is not very clear or definitive. I'm never really sure about the chip based oscillator and meter setup and would love it if someone could post on how to make a traditional one. Some other guy on this forum sells his version of the PYE. They came after this build so probably used a lot of ground work covered here but they don't share the winding / core information. Apart to say it can be easily built.
I don't have the Collective Cases panel, but I believe that it is combined with the bypass switch (I think it is Bypass/In/Off), top right knob of the panel.Can anyone share where you installed the on/off switch, I haven't received the case yet, but it looks like there is no on/off switch location on the face of the collective case.
What should the voltage be at u1 molex B- to B+I here ya
Is anyone recently, or presently working on this build? I am getting close to completing one channel, still waiting for the case to be shipped.What should the voltage be at u1 molex B- to B+
Hi sr1200, I am presently trying to get one channel on the PYE compressor to work, it looks like your one of the few people who got it to work properlyIt was the only one that mouser had in stock at the time. I got it to fit and work, just not as elegant as the bournes trimmers. +1 on the schematic thing. I haven't been able to get mine going yet. Once I do I'm going to write up a little build guide for it though as this project kind of needs one. There are a bunch of questionable things with the project that need clarification.
