skal1
have got bypass board in? , if you have just buy a 1pole 2pos. rotary switch
I'm referring to the NPN VT12 on original Schematic or TR14 on the PIE build. The reason I used a 2N3904 was just to see if the issue was hfe related (which it is) as this is the lowest hfe NPN I had available. This is particular relates to the oscillator. If you are using the IC version then this is not an issue.No BSY95A I use the V405 ORIGINAL SGS PNP cost £5 for two
not using 2N3904
I wanted to a switch that was capable of 240v Off, On [comp in], Bypass). As per Abe's PIE design. My front panel is marked this was so I want to keep it that way. Currently I have a hole! If the switch is rated correctly this would not be an issue so thats why I asked what people used if keeping to the original front panel design.yeah just seen inside one, me personally would not hook up mains supply to that kind of switch that just me..
cheers
I did the same, its okay so. Two of Abe's boards are pulling far, far under the 150mA - this is allowed for Lorlins. I think this compressor is the least power consuming piece of my over 80 Outboard Pieces I have/built....I wanted to a switch that was capable of 240v Off, On [comp in], Bypass). As per Abe's PIE design. My front panel is marked this was so I want to keep it that way. Currently I have a hole! If the switch is rated correctly this would not be an issue so thats why I asked what people used if keeping to the original front panel design.
I bought about 10 different values of EPCOS / TDK Ferrite Cores from Mouser over here across the pond, to experiment with for the 250k oscillator but I haven't started the build yet.
- anyone got a source for the high permeability torrid cores
cheers
