vintage-mike
New member
I've been researching some information about the Pultec EQP-1A - I noticed that the Gyraf audio schematic has a 1K in series with the LF attenuate control, but the LF frequency selection capacitors only bypass the control itself (and do not include the 1K resistor also). In other schematics, the LF frequency selection capacitors bypass the control and the 1K in series with it. Does anyone know which versions is 'correct'?
It would seem that in the Gyraf (G-Pultec) configuration, this would mean the HF boost Q would be limited by the 2K2 bandwidth pot at low Q settings, and limited by this 1K resistor at high Q. Also providing an essentially constant Q with HF boost frequency selection and better isolation between the controls.
In the alternative configuration, the HF Boost Q would be limited by the 2K2 bandwidth pot at low settings, and by the parallel combination of the 1K and selected LF frequency capacitor at high Q. Resulting in a max HF Boost Q which varies, dependent on the HF frequency selection (getting sharper for higher frequencies) but also dependent on the LF frequency selection. (All other boost / cut controls being set to minimum)
I've seen measured graphs from units that appear to show both characteristics, If my understanding is correct I would assume that the former (G-Pultec) EQ behaviour is desirable because it gives better control isolation, which one would expect in e.g. a more modern EQ, however it seems that other (and some 'official' units do the opposite and have much greater control interaction. So, does anyone know which is 'correct'. Is there an error in the G-Pultec schematic, or is there in fact an error in the real Pultec schematics (that has now become imbued with some 'magic mojo' as a result? )
