letterbeacon
I did think that was slightly odd. I have a higher B+ than the one specified, if that makes a difference.
emrr said:so.....
.....why does your build have 27 dB more gain than it should? Am I reading that correctly?
that means a hum of about -71dBFS. That sounds about right, right?
lassoharp said:That being said, if you still find the hum level objectionable, if possible, you could try rotating the PT and see if it changes anything.
Unfortunately I've tried this to no noticeable affect
One other relatively easy thing to try, just in case. Clip in (Parallel) equivalent size filter caps in the PS. This is kind of covering two things: 1) the odd possibility that one of the new caps isn't up to snuff, and 2) the possibility that the circuit wants to see more filtering. I realize the theoretical numbers for the stock values are plenty for the amount of current this amp draws but it's easy enough to clip those extra caps in to see. I did have one SE preamp that seemed to want above and beyond what typical filtering should have provided and I wound up having to use a choke input filter in the PS to get things right.
