Actually in the BC-6A there are two identical power supplies. One powers the odd numbered preamps, the other the even numbered preamps. So I'd expect the supply's isolation resistor values to change little as each supply runs less than 6 preamps.
As for figuring preamp current look at the supply outputs that feed 5 preamps. You know the voltage drop from output to output, you know the resistor values, calculate the resistor current (i=e/r) and divide by 5. One could do a rough crosscheck by making some assumptions about preamp stage idle plate voltages and then calculating plate currents, but that would not be very accurate. Another approach is to measure one preamp using an adjustable HV supply. FWIW I use a recapped Heathkit SP-2717 (aka IP-17) that works well for powering tube stages (and for reforming NOS electrolytics).
Yes I forgot about the dual supply! Thanks for the reminder.
So I went and dissected the cascades of power for the dual supply BC-6A, on both supply #1 and supply #2. Putting it here below in case anyone in future can use the breakdown info.
It seems that RCA was fine with strapping either 4 preamps or 5 preamps to the same filter spec/cutoff design. Since I’m designing for 8 total, I’m wondering if it makes sense to implement a new split point like they do for the B5/6 + B7/8 rails. So use the source point for the preamp RC and tack on another RC directed parallel from that, and have each leg feed 4 preamps. So from the last break off point that would be a 600R/40uF > 600R/80uF >
B3 RAIL > 3900R/120uF >
B4 RAIL, two times in parallel instead of just the one leg, each leg feeding 4 preamps.
The transformer i have provides above 500mA, so that shouldn’t be a limiting factor.
I’m not yet sure how to interpret the current limitations of the 5R4GY.
https://frank.pocnet.net/sheets/127/5/5R4GY.pdfThe full wave specs in datasheet say that with 2100 “max peak inverse plate voltage,” it provides 250mA DC output current. At higher ”max peak inverse plate voltages”, the current output drops below 250mA (if using a capacitor not a choke). So my question is, what is the “max peak inverse plate voltage“ for this RCA power circuit? Wondering if i can hammer out the current limit for this setup. Also wondering if it can offer double 250mA, since it uses two plates. I doubt that though!
If the tube can in fact put out 250mA, then I need to do all of the math of all pcb’s and see if perhaps the high voltages total up less than 250ma. I believe each of the four 6V6’s will chew up about 35mA at all times. That would be 140mA total. So that instantly brings down the available plate current for the rest of the pcb’s to 110mA. Maybe that’ll be enough, since i know each pcb might only use something like 6-8mA. But if it doesn’t add up, and I have all of the above correct (about the 250mA limitation of the tube), then i may need a separate supply dedicated for just those four 6V6’s.
SUPPLY #1 Filter Cascade:
*100R >>>>>>>>>>>>> **
** 750R/40uF > B2: (unused rail)
** 3000R/40uF > B1: 5AR13 CH 1 LINE AMP
** 600R/40uF > 600R/40uF > ***
*** 5600R/40uF > B8 12K/40uF > B7 : (unused rails)
*** 5600R/40uF > B6 12K/40uF > B5 : 5AR11 CH1 BOOSTER AMP (CH 1 SUB MASTER)
*** 600R/40uF > 600R/80uF > B3 > 3900R/120uF B4: 5AR1, 5AR3, 5AR5, 5AR7, 5AR9
SUPPLY #2 Filter Cascade:
** 750R/40uF > B2: 5AR16 PGM-TB MON AMP, 5AR15 CUE FEED MON AMP
** 3000R/40uF > B1: 5AR14 CH2 LINE AMP
*** 5600R/40uF > B8 12K/40uF > B7 : 5AR12 PGM-TB.MON PRE-BOOST
*** 5600R/40uF > B6 12K/40uF > B5 : 5AR10 CH2 BOOSTER AMP (CH 2 SUB MASTER)
*** 600R/40uF > 600R/80uF > B3 > 3900R/120uF B4: 5AR2, 5AR4, 5AR6, 5AR8
