ioaudio said:
And again attacks from Montenegro. (edit: oh moby is from serbia)
Why should i post wrong or made up measurements?
If you have better data, why not come up with it?
The link to VAC shows no impurities - where do you read the 1%?
Why do you judge my transformer from the looks of the oxidation alone - without having tested anything - especially when you have "20 years as chemistry lab technician in the field of materials"?
Attack again? Serbia, Montenegro, what you are talking about? I'm talking about accuracy of your measuring.I don't understand this comment.
The reason of posting superficial measuring I don't understand either.
What data you want to see? VAC's Mumetall? No problem, give me couple of days and I will post it here.
Regarding impurities, all elements besides Ni76.6, Cu4.5, Mo3.3, Fe14.7 are imputities.
Also, I don't judge your transformer, just comment that your final heat treatment aproach is not the same as usuall used in the field of soft magnetics. If you use protective atmosphere as Hydrogen, or cracked amonia you will end with silver color but with partially yellow grains. Try to look original laminates under the microscope, you will figure out what I'm talking about.
Black oxide is visible by eye, and it's product of high dew point of the protective atmosphere.
At the end, if you produce something and take a profit for that you have to be carefull and acurate with the informations. Othervise, be prepared for criticizm and profesional suggestions to improve. You can ignore my comments but I can't ignore facts I see here.
