pfdoherty93
New member
I have a 1984 pulsar labs console that has been recapped before. The current caps are bipolar 35v 100uf electrolytic caps. I also have the schematics that say the caps that should be used are bipolar 47uf electrolytic capacitors (nothing about voltage but that doesn’t matter too much as long as I’m not going under what’s needed). My question is should I recap with 47uf or 100uf. The power supply I had to build for the console is way larger than what I thought would be needed and now I’m realizing that’s because every cap is double what was originally used. But will using larger capacitance improve sound quality or anything like that? I would think it would be best to use what the schematics suggest.
