Bear in mind: Don't expect this to have really low distortion. 3% ain't bad for something like that. AND you're going to need an additional 2 output transformers to even safely bench test for distortion, and run speakers, given the outputs are at B+ voltage ref to ground.
You have a short wave, AM, long wave, FM radio. I'd keep it.
I suggested a 70 volt 10 watt distribution PA matching transformer as they have multiple taps to hook up a speaker. You need 800 ohms to see it. But you could also hook up an 800 ohm load resistor and use a 2 channel scope to read the voltage and see the waveform. Or use a DMM with 20K freq response as a floating meter, no ground, across the resistor. Square the voltage and divide by 800 to get the power out in watts. Or use blocking capacitors after the load to allow grounded bench equipment to read the output.
Lots of ways to figure it out.
I hope you get some fun out of it. Good luck.
Hope you get some fun out of it.
